Looking for the size or part no. For rev3+ bellhousing to engine bolts.
Cheers,
Ryan.
[Mk2] [Turbo] Bellhousing bolts
- IMOC Moderator
Re: [Mk2] [Turbo] Bellhousing bolts
Cheers Gaz. Think I've managed to get what I need from that. I'll have to save this site!
It's mega useful! Can be a bit tricky to find bits sometimes as they can be hidden away under a less obvious parts group. Pretty much everything is in there somewhere though!
- IMOC Moderator
Very handy mate, Thanks again. I just screenshotted the page, Underlined what I needed and emailed it to Toyota
Did you click on the parts to get the full PN's?
31105G is the "group" basically, not the actual PN. Number in brackets after the PN is the quantity needed.
- IMOC Moderator
Oddly the guy from toyota just got back to me asking which one of those three I need. I actually have no idea. I assume the ones dated 93?
Probably all of them.
If a part is only for a specific range of years, then it would say 12/1989 - 11/1993 for example, indicating that part is Rev1 / Rev 2 only. from the top of the screen the parts chap is looking at 12/1993, which is Rev3.
If you refer back to my screenshot, 31105G refers to 4 different bolts (see the other parts in that group are highlighted red), which is why it lists multiple options. It also tells you the spec of the bolts so from that you can work out which one is which, if you're after a specific bolt only.
- IMOC Moderator
I'm only after thre from the bottom of the bellhousing This is mega frustrating ha!
Are those the smaller ones? I wonder if they're the bolts labelled B, which are standard Toyota bolts rather than anything vehicle specific?
- IMOC Moderator
That's what I thought too and when I google the pn for "B" it does come up with a bolt. From looking at the bellhousing I can see they would be shorter than the others. Maybe about 60mm?
- IMOC Moderator
The nice man at Toyota is gonna order the bolts but said in this instance he will accept a return if they're the wrong ones.
- IMOC Moderator
Yeah, He's sure the bolts i need are the 3 varying ones you out a pic up of. I'm not sure they are at all but if he's happy to take them back then I'm happy!
