[All] [Generic] Wheel nuts not marking with socket
wilkie senior
Post by wilkie senior »
Hi
ok chaps how do you look after your nuts?
Ive had cheapies expensive & they all suffer when putting them on & off
best way ive found so far is to wrap them in masking tape tighten up and remove the tape
Ive never found a wheel socket with a teflon lining, which i thought would work?
how do you folks take your nice sparkly shiny coloured nuts on & off without marking them.......oo err missues :-)
Brian
Alex O
Re: [All] [Generic] Wheel nuts not marking with socket
Post by Alex O »
I have just bought some Rota wheels and they came with "tuner nuts".
The outside of the nut is smooth and round and the inside is like a torx bit. You need a special socket to tighten and remove but the alloy socket so far has not hurt the black paint on the nut.
This has the added advantage that the socket does not scuff the wheel around the holes either.
This is the kind of thing...
https://www.ebay.co.uk/i/273040914838?c ... 120&crdt=0
wilkie senior
Hi
Yeah thought about going to tuner nuts, we had them on the sparcos in the garage, but our nuts & tool!!! (pardon the expression) where worn
I will look into it as you say no chance of damaging outside, i wia just wondering some of the "socket" nuts ive seen around how people manage not to mark them
Cheers for the suggestion
regards brian
SonicSW20
Post by SonicSW20 »
Common problem, a member on here had one of his (for Sparco NS2's) get stuck on, and the nut deformed and also deformed the splines on the tool. Not good!
Best value nuts are the Driftworks own brand steel ones IMO.
wilkie senior
Hi
had a look on drfit works
their own brand of normal "socket" nuts, have you had experience as to how well the powder coating stands up to using a socket?
cheers
SonicSW20
Post by SonicSW20 »
I have the external splined ones, they have a bit of damage / rust on them now. They are about 3 years old and have covered ~80,000 miles or so in all weather.
https://www.driftworks.com/spline-drive ... lable.html
They still clean up OK. If I wanted them to be perfect I'd have no issue dropping another £32 on them to replace them every few years!
rossonza
Premium Member
Post by rossonza »
throwing this out there..... have you looked at wheel nut covers? go on after youve done up the wheel nuts.
wilkie senior
Hi actually my lad wilki said the same thing
his mrs car has chrome covers on hers
Im torn between unleashing the chav in me, or being sesible :-) re style & colour
rossonza
Premium Member
Post by rossonza »
wilkie senior wrote:Hi actually my lad wilki said the same thing
release the inner chav! :mrgreen: :mrgreen:
