Silly question Ive bougjt rev 6 headlights new
And Im wondering how hard the are to fit and if anyone has any good/useful
Tips???
Fitting rougue headlights
Too weird to live, to rare to die
Re: Fitting rougue headlights
Have you got the official instructions? I can email them to you if not.
My biggest tip would be to make sure you fit the M6 threaded bar that stops the lights bouncing up and down when raised.
Thanks yea got everything as its new kit bought of Alan Bryson
So everything ready to go including modified brackets so its not that hard a job?
It'll take a couple of hours, but it's not that tricky...
Nice one thanks for the reply just on with it now
- IMOC Moderator
Mark
if its only a couple of hours you can do mine at JAE ha ha
Ive had a set for a while I bought them for wilki the younger when he had the cosmos.
Would like to get them on but I was banking on a weekend doing one sat & one sunday.
I dont why im apprehensive as i made those puma lists fir the white eagle !!!
I have a set of instruction somewhere but if you can email or fb message me that would be handy, so how many burgers to fit at JAE ha ha
Oh Benjo, let us know how you get on
Brian
Brian
OK, it was 6 years ago when I did it.. maybe it's more involved. My memory has faded with old age
- IMOC Moderator
Perfect oppertunity for you to recolate in September !!!! ha ha
Last edited by wilkie senior on Thu Jun 14, 2018 12:58 pm, edited 1 time in total.
Brian[/quote]
Ill be honest its not a fun job definitely doable but
Very annoying Ill quite happily pm you my number
And have a chat about it lol not finished yet but Im
Sure Ill sort it
Brian[/quote]
Sure Ill sort it
So I finished fitting them today not going to lie not a fun job
But very satisfied with the finish,
2 recommendation
1 after moving the plastic clips on light covers make the bolt holes
Bigger file or dremel this gives better adjustment later
2 put masking tape on bodywork around light to protect paint
2 recommendation
- IMOC Moderator
Hi cheers
I was thinkin load of masking tape over the area first as i scratched the white eagle when i made the puma quad heasdlights fit
pic of clip you mentioned?
Ref clip so the metal lid/top the bit you see when your lights are down.
You have to reposition the yellow clips that the cowling screws into
Then you use the the empty holes to bolt the lid to the light unit.
Its those holes I found it helped it you file/dremel them bigger to
Allow more adjustment to get lids sat right when lights are down.
Hope that makes sense
- IMOC Moderator
I think so you mean this bit
Yep you got it pal so after you moved the yellow clips widen the holes
Without the yellow clips,they only really want making bigger to allow
Lid to sit higher and more forward, when you get to that stage it should
All make sense.
Also I swapped my little side light bulbs for tw4 led (halfords sell them that look/fit same as a standard bulb they come in a box 3yr warranty) the ones that come with the kit give a orange color next to the white/blue main beam
All make sense.
- IMOC Moderator
Hi Thanks
I am going to renew all the bulbs with mine & as you have some brighter leds
MIne are 2nd hand with painted cowls so i need to rub those dowm going to take my time as they arent as easily available as mr2 std ones
