bleed nipples you'll prob be ok with while winding them back in if you're not forcing them in fast.
but the a bleed at the end is always a good idea so you need to think about the nipples.
Get some plusgas or other release spray on them and let them soak for a while, get a wire brush in there to clean it up.
use a 6 sided spanner and lighty shock them open.
a constant torque could just snap them or round them.
I just use the palm of my hand and thump the end of the spanner with that.
using a hammer is probably too much force.
should be able to fully fit the top nuts for the shocks off the car.
I use an old bike inner tube wrapped a couple of turns around the shaft and then grips on that.
Also always grip the very top of the shaft where the bumpstop would be covering.
This means all the tools are close to your hands which makes it much easier.
sometimes spring design doesn't allow this so the gap is a bit more.
big torque wrench helps too.
