First up my engine its had all the work done ie cammed, crank forged, 800cc injectors.
Okay so I have a link g3+ but not wired it up yet so I wanted to just start it up to make sure the engine is at least running, it starts but I have to hold the accelerater on if I let it off it will die right away.
Is it possible that the afm is seeing so much fuel that it simply cuts out or is something bigger here at play.
It does not have a adjustable fuel pressure regulator by the way not sure if I really need one but sint think it would cause it to not idle.
Lord help me please!!
