robbie_742003 wrote:If you take off the shroud, you should see a couple of bolts either side which can be loosened enabling you to adjust the headlight cover.
Rob
shinny wrote:
1) Remove black shroud via 4 screws:
2) Loosen these four bolts:
3) Adjust lid to it sits flush.This may take a few iterations of trial and improvement
- one method is:
a) pull the lid too high
b) lower the headlight
c) gently push the lid down so it's flush
d) raise the headlight to tighten the 4 bolts
e) lower the headlight to check it's still flush
4) Re-fit shroud via the 4 screws
