[Mk2] [Turbo] Rear suspension bush kits
rossonza
Premium Member
Post by rossonza »
Anyone recommend any particular kits for replacing the rear suspensions bushes?
Theres a few kits on ebay, just wondered if anyone had used any/recommended a specific brand
JAAASH
Re: [Mk2] [Turbo] Rear suspension bush kits
Post by JAAASH »
Many good kits out there, all doing very much the same thing.
I'm running Prothane bushes all round on mine and very happy with them. Much cheaper than most of the name brands too.
_________________
"What the Deuce?!"
My MR2 - http://www.imoc.co.uk/forums/viewtopic.php?t=174494
rossonza
Premium Member
Post by rossonza »
JAAASH wrote:Many good kits out there, all doing very much the same thing.
what supplier did you use? any ideas on costings?
Ross.
SonicSW20
Post by SonicSW20 »
Order the kit from Amazon US. Last time I checked it worked out at around £110 delivered, all tax paid etc.
rossonza
Premium Member
Post by rossonza »
can anyone post a link? on amazon usa theres so many to choose from, and i couldnt find an MR2 filter.
abovetherim
Post by abovetherim »
I bought a complete front and back from SBITS for around that price above but that was maybe 4 years ago.
If you want to contact Pete @ sbits he may not reply too quick as I seem to remember he goes to lemans and that is this weekend I think.
rossonza
Premium Member
Post by rossonza »
abovetherim wrote:I bought a complete front and back from SBITS for around that price above but that was maybe 4 years ago.
good to know, in no real rush for them. got a few months before i need them to install.
SonicSW20
Post by SonicSW20 »
Last time I checked (a couple years ago now) he was more expensive *and* didn't come with ARB bushes.
SonicSW20
Post by SonicSW20 »
rossonza wrote:can anyone post a link? on amazon usa theres so many to choose from, and i couldnt find an MR2 filter.
18-2009, check compatibility on the Prothane website.
http://www.prothanesuspensionparts.com/ ... a_mr2_1995
abovetherim
You are right about the arb bushes and I seem to remember he had a deal on as he got a few kits in.
rossonza
Premium Member
Post by rossonza »
hmm ok, maybe ill stick to usa amazon then
JAAASH
Post by JAAASH »
Apologies for the slow reply. I also got mine from SBITS. Can't remember exactly how much, but im pretty sure it was very similar to the amazon price Gaz has posted :thumleft:
_________________
"What the Deuce?!"
rossonza
Premium Member
Post by rossonza »
http://www.prothanesuspensionparts.com/182009
looks like the one, and it looks like its front and rear. Dont mind ordering from Amazon USA as im on no rush at all. be good to get all the bushes off to refurb all the suspension components
It says total kit, but is it really everything i need to refresh the front and rear end? seems cheap compared to the super pros ive had expeirence with on mx5's
amazon link
https://www.amazon.com/Prothane-18-2009 ... automotive
rossonza
Premium Member
Post by rossonza »
well ive ordered. £101 including shipping and taxes. why not :-)
pbmr2
Post by pbmr2 »
the kit doesn't include the rear toe bushes. the inner ones are easy enough to find but the outer ones in the hub are harder to track down. think I'm going to get 14mm bolt toyota ones.
SonicSW20
Post by SonicSW20 »
That's because they are not bushes, they are bearings. Personally I wouldn't replace the inner with a bush.
rossonza
Premium Member
Post by rossonza »
cheers guys, 4th august the kit arrives. :thumleft:
rossonza
Premium Member
Post by rossonza »
Kit arrived yesterday. May try and tackle some of them today :-)
SonicSW20
Post by SonicSW20 »
Have you got some measuring calipers? If so could you measure the thickness of the washers, and the inner and outer diameter? I've lost the washers from my kit 😕
rossonza
Premium Member
Post by rossonza »
Gazza_DJ wrote:Have you got some measuring calipers? If so could you measure the thickness of the washers, and the inner and outer diameter? I've lost the washers from my kit 😕
Ill get some and confirm for you! :thumleft:
