Hi all.
I have an issue with my clutch, it won't disengage.
The first time it happened I was at some traffic lights and suddenly I was unable to select 1st gear, so had to start restart the engine in gear and rev-match to get home.
I then bled the clutch and this fixed things, so I assumed either the slave or master had leaked.
It's then since happened several more times, only this time it seems like something else.
I've tried bleeding it, I've adjusted the pedal for maximum depression
(highest bite point), and the pedal feels heavy like it should, but still the clutch won't disengage.
Any ideas? Thanks!
