Hi
If the actuator arm had disconnected from your wastegate your wastegate would just be flapping around.
You would be seeing the car spool really slowly and it would take a long time to get to your peak boost of 0.9 bar.
as the wastegate would be opening immediately causing some exhaust gasses to bypass the turbine and not just opening to divert at the desired boost level.
Just from the way you are describing it, seems like the boost pressure is building up fine.
Then at the point you want the wastegate to open to prevent it boosting any higher the boost is just being lost?
Almost sounds like when your wastegate is opening its bypassing too much of the exhaust gasses from the exhaust turbine and the boost is coming back down.
Not something I have seen before.
If your wastegate was fouling youd probably see the opposite
(not able to bypass enough exhaust gasses to stop boost creeping up)
Id probably try checking and replacing the vacuum lines on your actuator, and turn the manual boost controller off.
See if you can hold the stock boost level without that tailing off then slowly increase your MBC.
