I have the engine out and need to change the water pump and cambelt.
I can see that getting the bolt loose on the bottom pulley will be a tough one and have a very long bar.
What's the safest and easiest way to lock the engine?
Gazza_DJ wrote:Heat up the flange on the bolt if it's the earlier one piece design to give you a fighting chance.the later washer type ones come off much easier.
ashley wrote:
Except the crank pulley is made of two pieces of steel sandwiched together with rubber which really doesn't like heat![]()
mr2magic wrote:Impact driver?? On a crank shaft? You do realise there are conrods attached to the crank and that these have journal bearings..
the bearing surface doesnt take kindly to repetative radial force of the kind caused by impact guns.
The above method is used(with minor alterations and special tools) by almost all manufacturers.
mrdb wrote:Breaker bar with one end on floor.Pull coil lead.
Flick starter it will break it free and then just remove with ratchet.
tiff_lee wrote:mr2magic wrote:Impact driver?? On a crank shaft? You do realise there are conrods attached to the crank and that these have journal bearings..
Can you expand on that at all? The crankshaft would barely be turning(if at all) using an impact drive so what radial force is there on the journal bearings?
