Hello there,
Just a quick one, how do you remove a single wiper conversion? I have one on mine and want to revert back to 2 blades, but i know the mechaism must have been changed as it sweeps the whole screen.
Any ideas?
how to remove single wiper conversion?
Re: how to remove single wiper conversion?
From what i can see, the mechanism is bloody hard to get into... if your after a two wiper mechanism, I have one kicking about spare if you want to have a crack at changing it all back to stock ??
Well its just i need a new wiper blade, and it bugs me the way it lies half way accross the passenger window at the moment.
I gues ill have to remove the platsic grille and see what i can do.
Is yours converted to a single unit also?
Graham
Graham
No no... stock setup ... should ebay it off if its a 180 degree sweep.. probably get some good money for it !!
Really?
In that case i may do so, althought it needs a bit of a touch up. I could do with taking a pic of it really and then seeing whats best to do with it!
Are replacement wiper blades easy to come by?
How long is the blade Hurstie ??
Just measured it, 25 inches
