She started life as 93 Rev2 running 330bhp.
She now has the following build spec:
Engine
2.2 HKS Stroker
A/C radiator, pump and piping removed
Aerotek anodized engine bay bolts
Link G3 Pro ECU
K&N 4 Filter
Custom 4" Turbo Intake Pipe
Garrett GT30/40 Turbo Kit and Down Pipe
Screamer Pipe
Full Race' Exhaust Manifold
CNC Custom Intake Plenium
ARP head studs
ARP main bolts
Balanced crankshaft
Balanced HKS pistons
Balanced rods
80mm Mustang Throttle Body
Denso Iridium plugs
Earls side mount oil cooler kit
Gas flowed, ported
Oil Catchcan with KN race filter
Blitz Nur Spec R Exhaust
HKS 1.8mm Triple Layer steel headgasket
HKS 264 duration cams
Titanium Valves
Aftermarket Valve Springs
Ferrea Valve Locks
HKS Duralumin cam pulleys
HKS SSQV BOV
HKS Rods
HKS valve springs
HKS 86mm pistons
HKS Twin Power ignition amplifier
5S Crank
Clevite Bearings
Custom fuel rail
Twin Walbro 255ltr/hr fuel pumps
Uprated Earls Fuel lines and Connectors
Bosch 040 in the boot with Swirl Pot
Fuel Collector Tank in boot
Fuel Pressure Regulator in boot
Power Enterprise 1000cc injectors
Custom Boot Mount Charge Cooler
Custom Boot Mount CCr Swirl Tank/Dry Ice
Radtec Front Mount CC Radiator
Revision 3 OEM igniter
Revision 6 Rogue deluxe fan kit
Braided Water and Oil Lines
Magnecor 8.5mm leads
TTE 3 bar MAP sensor
Transmission:
B&M Short Shifter, 75% throw reduction
Revision 3 OEM uprated gearbox
Factory Fitted TRD LSD
OS Giken flywheel
OS Giken Triple Plate Clutch
Front pulley, crank and clutch all balanced
Suspension, Brakes
BC Racing Coilovers
Cusco front
Cusco Brake stop kit
K Sport 330mm 8 Pot Brake Kit Front
3G 20-GR Uprated discs with C/C painted calipers rear
HEL Stainless Brake line kit with carbon sleeves
High
Tanabe Sustec front and rear sway bars
Rota Force 17"
Rota Lightweight red forged nuts and valve caps
Motul Dot 5.1 brake fluid
Interior:
Alpine MP3 Head unit and cd changer
Black alloy gear knob with
Black velour mats, roof liner, sun visors and light housing
Carbon Fiber surround kit for dash, dials
Display for Boost, Oil Pressure
Leather door cards
Personal 330mm Neo Grinta steering wheel
Reclining Recaro Sports Seats with Bride sub frames
Stack ST8100 dash with Sard carbon surround
AEM Digital Wideband UEGO AFR Gauge
Blitz Dual Solenoid EBC Spec R
Blitz turbo timer
Exterior:
Fully stripped and professionally resprayed in 2012 in vibrant super red
Spoilerlous rear boot
Carbon Fiber side air intake vents
Ganador carbon electric wing mirrors
Clear side lights
Hydraulic gas engine lid strut
JDM Reg plates
Rev 3 Rear lights with USDM tail corners
T-Bar Carbon Fiber removable roof with custom carrier.
Toyota OEM Mud flaps
HKS lower front wing decals
Power:
Estimate 500/600BHP
Always serviced and fully maintained with Opie oils and fluids.
Bad Points:
PH link: http://www.pistonheads.com/classifieds/ ... bo/6762145
I know the pics are poor; they're all I have to hand at the moment.
I'll update this thread as and when I think of other things to add.
Stephen
07500 842581
