Im looking to buy one for my NA. what is involved in the instalation?
Also is there anything I should look out for when buying one, such as the hose sizes?
Anyone reccomend a specific one for the NA?
Catch cans - Installation
Re: Catch cans - Installation
Don't bother... your better off fitting a breather filter to the end of the PCV - vent line coming from the cam cover, then plugging the one that goes into the throttle housing.
Cost effective and no more oil being pulled through by the engine !
cheers cranky, ill have a look into those too :d
doing that caused cold idling problems on a few n/as i know of, whereas catch cans worked effectively.
p.s. 11mm hose for n/a 15mm for turbo
'97 mk1 Mazda Eunos Turbo track car with 260bhp/ton - soon more as Chris Wilsons going to build me an engine over the winter ) .
steve b wrote:doing that caused cold idling problems on a few n/as i know of, whereas catch cans worked effectively.
Understandably, the setup of the engine is designed to be sucking in the gas from the PCV line, but you should be able to compensate this by turning the base line idle control screw .. opening the air channel a tad more.
Totally up to the individuals preferance.. though installing a catch can is quite a considerable cost offset in comparison to a breather filter.
Both work, one has more bling !
Just bought a Greddy catch can for mine! I love engine bay bling
RedMR² wrote:Just bought a Greddy catch can for mine! I love engine bay bling
TART
Cheers steve & JJ. , yeah ill have a look into those too, I just dont want to upset the engine in any way as it's running good at the mo, obviously want to maintain this
