Advan Sa3r
Advan Sa3r
I'm after some advan coins and c clips for a set of Advan Sa3r. I appreciate these are super rare. So my thought is can I get some cases clips and make up a coin to fit. Does anyone know the exact size of the car clips and coins?
Re: Advan Sa3r
I have the coins but no clips. If I remember tomorrow I will see if I can find them and measure them for you.
I did pick up some circlips the right diameter but they are to thick to sit in the grooves, probably due to the fact mine have been powdercoated.
I was considering getting some stickers designed but never got around to it.
Re: Advan Sa3r
OK just remembered to check!!
Diameter of disc is 47.4mm and thickness is 3mm
