Removed from my Rev3 turbo due to having a caldina 3sgte fitted.
Includes everything you need wiring and running wise for a Rev3 conversion including the injectors and rail. After £300 for the lot.
I also have my Rev3 head and a the CT15 turbo off the caldina engine as im using my CT20 hybrid. The ct15 gives a really fast spool due to the turbo and exhaust manifold being a one piece cast.
Rev3 head £50 (can include once used arp headbolts for £40)
Caldina CT15 turbo £200 (will only fit Rev3 head)
Please pm me with any inquiries
Rev3 engine loom, ecu, injectors etc
Re: Rev3 engine loom, ecu, injectors etc
Ecu conversion and headbolts now sold.
Head now sold
Cuál sería el precio de envio para las islas Canarias?
Sabe si el cableado serviría para un Celica GT4 ST185
Muchas gracias !!
Muchas gracias !!
Did you modify the exhaust manifold of the CT15 or is it stock a bolt on to the cylinder head of a GEN3?
Also does the downpipe of a GEN 3 fit directly onto the CT15?
Yes the stock ct15 manifold will bolt directly to the rev3 head without modification but you will need to modify the downpipe to fit.
The gen4 conversion is really popular in the states if you Google im sure you'll find out exactly what needs to be done. I never planned on using the ct15 so it wasn't something l researched.
Do you still have the ECU?
It went with the ecu conversion mate
Oh well... Can't blame a man for trying!
Good luck with the sale mate!
