After some help, I'm just setting up my rear bump stops on my 94 rev2 n/a running k sport coilovers.
So now started looking at possibly bent lower arms or binding on the bushes, stripped them all down and checked all were straight and were even side by side, I've just fitted poly bushes to the arms and refitted them back on checked but found there's no change at all??
With the car under load I measured the end of the tie rod down to the floor
When the cars sitting on its wheels you can see the car sits higher on the n/s/r and this is without any weight in the drivers seat, I know I can adjust the ride height on the coilovers but don't want to mess with the shock travel.
Just seeing if anyone has had any similar issues or got any ideas??
Cheers in advance, scott👍
