As stated.
Plugged in new bulb and the bulbs flickered once then never came on again. The switch in cockpit doesn't have the usual green light behind it either, what could it be?
Fog lights not working.
Toyota MR2 - 3S-GTE - 1991 Turbo - Yellow
Re: Fog lights not working.
Front or back?
If the rear you may find it has been poorly wired (mine was) so all the power going through the lamp in the switch and the switch and not running through a relay. This puts too much power through the tiny bulb and pops it and possibly then breaks the circuit.
