I'm having a major clear-out and many of these parts will be weighed in along with the rest of my scrap at the weekend unless somebody wants them
ALL PARTS ARE FREE TO COLLECT - But if you want them posting I'll have to charge something as I don't have much time for that.
Rev 2:
Engine block - Bored to 86.5, some pitting in bores, recommend it would need taking out to 87mm to correct this. Apart from that fine.
Head - dirty but fine, probably needs a skim, valves included
Rocker cover dirty
Inlet manifolds x2
Throttle bodies x2
Distributors
Lot's more engine related bits and bobs, please ask
FREE PARTS - Engine block, head, manifolds throttle bodies all must go!
Re: FREE PARTS - Engine block, head, manifolds throttle bodies all must go!
have you got a rear turbo gearbox mount? Both parts of it.
Quite possibly. Haven't got that here at home but probably have at least the part that bolts to the body at my unit
Valve springs
Valves
Exhaust manifolds
Tvis butterflies x2
All good condition parts real shame for them to be scrapped!!
Valves
Exhaust manifolds
Tvis butterflies x2
Hello fella.
If you need these gone, I can collect this weekend. i will take as much as I can fit in my fairly large estate. Don't scrap them, senseless scrapping good parts!
I would take the block and head if i was closer
tehdub wrote:Hello fella.
Hi, OK, aiming to have it all laid out on Friday and go through it with a mate to see what he wants, then rest will be weighed in Saturday morning. If you send me your number I can send you a Photo on Friday evening of what is left if you want?
