parts left from breaking rev 3 turbo
Cars being broken - please contact a member of the Committee or a Moderator before posting.
Jamitsi
Post by Jamitsi »
i still have some parts left from breaking my rev 3 turbo
the car will be going soon, so if any parts anyone needs, this could be last chance
Air con Matrix £10
Air con long pipes( front to back) £10
Heater Matrix £10
Heater blower/fan unit £10
fuel tank £10
space saver wheel/unused £10
heater pipes (front to back) £10
Coolant pipes (front to back) £10
wiper motor and linkage £10
ABS unit £10
battery to starter cable £5
front loom and fuse box (frunk) £10
Accelerator pedal and cable £5
washer bottle and pump £5
Frunk pull catch and cable £5
passenger side headlight cover £5
coolant radiator and fans £10
cover in frunk (small split) £5
indicator/light/wiper stalks £5
boot carpet £10
boot boards £5
a lot of interior parts, carpets, centre dash(vents), visors, glove box, centre cubbies, a, pillars( divers broken at the lower part of the door, tin top), cubby behind seats, sill covers,
probably a quite a few parts i have missed, also lots of nuts and bolts
also apexi turbo timer with sw20 loom,£40
all prices plus delivery and paypal charges, obviously some parts will be collection only.
any questions just ask.
jamie
mr2nut123
Re: parts left from breaking rev 3 turbo
Post by mr2nut123 »
Your centre vents in perfect order mate? Mine have clearly has cup holders on them and some numpty has torn them off and snapped the middle fins.
Can I exchange my loyalty points? :lol:
qwakers
Post by qwakers »
have you got the heater control cable?
monkeyra
Post by monkeyra »
I'd be interested in:
And do you have the following?
1) Tintop headlining
2) The coat hooks which go beneath the rear window
3) The piece of black dashboard trim that incorporates the ignition switch
4) Drivers footrest (in the footwell) - I need the clips as I bust mine removing it the other week :(
SW20 Rev1 Supercharged 2GR-FE Powered Trackday Car.
Jamitsi
Post by Jamitsi »
Pms sent to all
Jerry
Post by Jerry »
Do you have All air con related to make non AC car -> AC ?
Jamitsi
Post by Jamitsi »
Jerry wrote:Do you have All air con related to make non AC car -> AC ?
Hi
I only have the front to rear pipes. And the matrix
Other parts have been sold.
Jamie
qwakers
Post by qwakers »
have you still got the boot carpet and the little cubby below the radio
many thanks.
rainen
Radiator
Post by rainen »
Have you still got the car? I'm just looking for the rad fan temp sensor out of the radiator if you can get it out (19mm long socket)? Thanks.
tottacrolla
Post by tottacrolla »
Air con matrix still for sale ?
tehdub
Post by tehdub »
Hi Jamie,
Does the Frunk loom have the connectors for the speedo/gauge cluster?
I don't need the whole loom, just the connectors with about 6 inches of wire hanging off, but happy to have the whole thing if it is easier.
Cheers,
Tom
SonicSW20
Post by SonicSW20 »
Do you have ABS hubs, if so is the passenger rear hub available / is it in decent condition / complete with sensor?
Skinner248
Post by Skinner248 »
Driveshafts?
Return to “MR2s Being Broken”
