I've got a little project for someone here.
I got this in a bundle years ago and just never got round to doing anything with it.
Its been sat in my workshop ever since and I need it gone.
When it came to me, it already had the following work done to it -
New kind bearings
new rod bolts
new main bearing bolts
new toyota gasket kit
head skim
new piston rings
I just don't have time to finish it off. Its a project that someone needs to take on and do properly.
There are some bits missing, but I would say 95% is there.
It comes with a brand new flywheel and clutch and some other new bits.
I want £600 for it, which considering the parts that are in it, and what comes with it is very reasonable.
[FINALIZED] 3VZ-FE
3VZ-FE
What is not included ?
I got MK2 REV1.
What else will I need to put the engine in my car ?
Have You got ECU for it ?
Is the gearbox good to bolt on or will I have to modify something ?
Is there anything else I will need to modify if so ?
Phone number please.
Re: [FINALIZED] 3VZ-FE
