Caldina st215 engine q?
MR2Kyle
Post by MR2Kyle »
Hey folks, for insurance reasons I have to declare my engine swap but I can't find the engine number as it's so tight in there so I was wondering if anyone knows where the number is so I can concentrate in that area ect. Is it just under the inlet manifold?
Thanks folks :thumleft:
Mk1b 1989 Mica Blue
Mk2 rev3 1993 NA Turquoise
Mk2 rev5 1999 Cosmos Blue with st215 conversion 😉
pbmr2
Re: Caldina st215 engine q?
Post by pbmr2 »
I'll go into the garage and have a look at mine, will report back.
pbmr2
Post by pbmr2 »
Ok, that's weird. Really can't find anything other than Y11* which seems like a part number rather than an engine number.
Nothing stamped on it anywhere. Got the block on a stand so great access but there is nothing.
MR2Kyle
Post by MR2Kyle »
Hmm well I'm on the Australian caldina forum and they said that they just plug the car into the obd port and it says there somewhere 8-[ so will give that a go too once the cars out again next spring 😁 thanks for looking :thumleft:
Mk1b 1989 Mica Blue
pbmr2
Post by pbmr2 »
but if the ecu was swapped or not original then it will have the wrong number. hmm
got this same issue as mine is being installed this month
MR2Kyle
Post by MR2Kyle »
At the moment I have the standard auto ecu that was on the caldina the engine came from....and for some reason the engine won't rev over 5800rpm but that is besides the point....hopefully I will find the code in the computer but as you say it's an issue if you don't have the standard ecu! #-o
Mk1b 1989 Mica Blue
