[FINALIZED] TRD LSD
Parts for the Mk2 MR2 only (excluding bodywork and wheels/tyres)
pistol pete
TRD LSD
Post by pistol pete »
As Above
I have a TRD LSD in a mr2 mk2 Na gearbox
Used in my sprint car, worked really well
No longer have a mk2 so no use to me
will also fit a ST202 celica
The gearbox itself has a crunchy 3rd gear, so you can either repair the crunch or just remove the diff
Located in Kent
£350
bri0905
Re: [FINALIZED] TRD LSD
Post by bri0905 »
Pete
What's the difference between this and the std lsd?
Bri
96 Rev 3 Turbo, Done!
pistol pete
Hi
Most na's didn't have a lsd..
Also I think that the stock one is a vkscous type where most have worn out by now and this is a plate type.... It was fantastic on track and really helped the handling
But for finer detail you will have to refer to someone with more knowledge
bri0905
Post by bri0905 »
I have a turbo with std viscous lsd but always looking for improvement.
Where abouts are you pete?
pistol pete
Im down in kent mate..
Youll have to check with someone like peter gidden that it will fit a turbo box..
But yeah its a big improvment.
You can change itmfrom 1.5 to 2 way upon installation too
Race Idiot
Post by Race Idiot »
I'm pretty sure the NA and Turbo LSD's are different
http://www.trdparts.jp/english/parts_ls ... nical.html
Different part number at least.
SonicSW20
Post by SonicSW20 »
Don't think Turbo driveshafts will fit an NA LSD either?
bri0905
Post by bri0905 »
Ah right. Didn't realise.
I'll pm peter later and ask the question.
Simarshy
Post by Simarshy »
I would say most factory Viscous ones will be acting like open diffs by now. I know mine was completely open when I replaced it this year.
Feedback Bot
Post by Feedback Bot »
Return to “Mk2”
