My mods are
Decat
Scorpion exhaust
Apexi induction
Ebay mbc.
I have also changed dizzy and rotary arm, sparks, coolant temp sensor and clutch
tiff_lee wrote:I realise it's all a bit subjective but any recommendations on a good EBC?
I just took a look and it seems Greddy, HKS, Blitz etc all seem to offer very similar products with nice gucci displays.
FEATURES:
- Boost Map Correction
- Fine boost tuning settings via 10x10 boost maps
(Load vs Duty
- Boost Correction by RPM, Throttle Position, Speed, Gear Position, or Water Temp
- Additional Profec monitoring and data loging via PC software
- AUX input for Over Take Boost Function future using optional Remote Switching System
- Plugs-in easily in between Profec Display/Control unit and Profec main unit
- Additional connections depending on application.
- PC Compatible
(Profec MAP software) with use of mini-USB to USB cable
(sold separately)
- OS:
(Japanese, English) Windows Vista, Windows 7
(32bit, 64bit)
- CPU: 1GHz or more 32bit or 64bit processor
- Memory: 1GB or more
- HDD free space: 20MB or more
C35Rob wrote:I stand corrected! it seems that the EVC 6 is kind of mappable- news to me, looking at the manual it's all done through the display though, which seems a lot more clunky than a PC based software, the greddy allows datalogging too which is nice.
mappable boost is by far not essential, but a'nice to have' especially if you want to limit boost in first for traction, slam the boost in hard in lower gears, but feather it in in higher gears where there's more load on the motor, for example.
the profec MAP is on my"want to buy" list, but there's other things I need before that
azznwab wrote:So I've looked at some adverts on ebay and noticed the greddy profec type s has manual analogue style nobs while the type b has digital display.![]()
I'm only guessing that the only difference is above
(please correct me
So can someone please explain what the low boost, high
boost and gain adjustments actually do thanks
C35Rob wrote:tiff_lee wrote:I realise it's all a bit subjective but any recommendations on a good EBC?
I've got one of these mate
http://www.rhdjapan.com/trust-greddy-pr ... e.co.uk%2F
which I'm more than happy with..
GReddy have recently released this add on too
http://www.rhdjapan.com/trust-greddy-profec-map.html
which looks like an awesome bit of kit- makes the controller properly mappable:
FEATURES:
(Load vs Duty
- PC Compatible
(sold separately)
- OS:
(32bit, 64bit)
whichno
other stand alone boost controller can do, the only way you'd get those features otherwise would be with a high spec standalone ECU
