One job I wanted to do is check the wiring for the Lambda sensor.
Also could we clarify/confirm that there is only 1 lambda sensor???
![Think :-k](./images/smilies/eusa_think.gif)
If i was to take a guess I'd say the top/higher sensor is a temp sensor as it seems to be only 1 wire and the t'other one lower nearer to flexi is the lambda as it has 2 wires???????
Could someone possibly help confirming the pinout for both sensors on a rev2 turbo and if possible confirm the colour code for the wiring.
The top of theses two sensors has a broken wire and I am unsure where to reconnect it.
I have reconnected it to where I think it came but i would like to check with a meter.
Any help would be very greatfully received.
