I just went to fit my mongoose exhaust as I currently have a horrific 5" tip custom backbox and sports cat, and the flanges were miles out!
Just want to confirm it is a custom piece before I swap it out for an OEM one.
Cheers!
Gazza_DJ wrote:Stock Rev4 and Rev5 NA front pipes do not have a flexi.Instead, they use sprung bolts to the manifold and a different type of gasket.
Manifold on a Rev4/5 is also different to a Rev3.
Rev4/5 NA doesn't have the annoying 2 bolt flange and heat shield o2 sensor fitment- instead uses an M18x1.5 bung with a screw in type o2 sensor.
Much easier to change when needed.
The catalytic converter/ backbox fitment is the same though on the Rev4/5.
Measure the length of the cat
/ decat you have with the mongoose
- it should be
~420mm.
