60mls from full tank to 1/2 way on gauge ?
which i double checked, with same result !
Even been "less eager" with the right foot an not trying for a ticket every given chance made little difference.
So rather than pickle my brain further reading posts of others woes .....
If anyone can translate my emissions results etc ..
And minimize stress,both to wallet and mind,??
details relevant.
95 rev 3 turbo induction kit, hks bov, 3",decat, and exhaust
gizzmo ebc at .73bar ... 7 gain ( just fitted, same time as decat )
oem smic ( hence safe boost levels)
test figures
test 1 .......... test 2
co- 6.577 ...... co-3.838
hc-301ppm .... hc-118ppm
lambda-.903 ... lambda- .930
natural idle ... co-6.510
ANY ADVICE OR POSITIVE REPLY APPRECIATED
failing that, how do i get hold pete at sbits ??
60 MILES FROM 1/2 A TANK... and lambda not prime candidate ?
Re: 60 MILES FROM 1/2 A TANK... and lambda not prime candidate ?
Have you checked for fault codes ?
nothing showing code wise but having spoken pete g (sbits)
It IS lambda related ( f****d)
took time to explain how,why and effects ect, (of what now seems obvious)
time 4 new lambda methinks<
cheers for post tho m8...
Your hc is waaaaaaayy to high which means there is probably an awful lot of unburnt fuel. That could be injector related but i would also assume the O2 sensor to be the culprit.
