[Mk2] [Turbo] Clutch making strange noises
mr2nut123
Post by mr2nut123 »
When I reverse, that's when it makes the most noise. It sounds like a slipping/whine noise, and considerably louder if reversing up a slight incline when under a bit more load. This was the only issue at first so I thought nothing of it.
Today, once warm, I noticed that after changing from 3rd to 4th gear, it was making a slightly higher pitched whine noise at around mid position on the clutch pedal, just as it was disengaging.
There is no slip even in 5th gear at speed, so I don't think the noise is actually the clutch slipping. Any ideas?
mr2nut123
Re: [Mk2] [Turbo] Clutch making strange noises
Post by mr2nut123 »
? :-k
SonicSW20
Post by SonicSW20 »
Release bearing on the way out, perhaps?
mr2nut123
Post by mr2nut123 »
Gazza_DJ wrote:Release bearing on the way out, perhaps?
Is there any way to check this or replace with axle stands, or is a clutch out jobby?
mr2garageswindon
Post by mr2garageswindon »
Gearbox out to replace release bearing I'm afraid.
mr2nut123
Post by mr2nut123 »
mr2garageswindon wrote:Gearbox out to replace release bearing I'm afraid.
I'll just keep driving until I get an issue then I guess. It's only a sound at this point, no slipping yet.
Is the figure of £300-400 for a new clutch and labour still about right?
mr2magic
Post by mr2magic »
I suggest a change of transmission oil - when was it last changed?
mr2nut123
Post by mr2nut123 »
mr2magic wrote:I suggest a change of transmission oil - when was it last changed?
I'm not sure actually as I haven't had the car long. DIY job at home in the garage? Which oil is recommended for it?
SonicSW20
Post by SonicSW20 »
Yeah, it's doable at home, just a drain plug and a fill plug. You can either use a hand pump to fill it (like this http://www.coleparmer.co.uk/Product/Han ... ed_id=3482) or use a tube and funnel.
Make sure you can undo the fill plug before you undo the drain plug!
A lot of people swear by MT90 for whatever reason, however I know plenty of people who used similar oils from other manufacturers (Castrol Syntrax for example) and they are just fine.
mr2nut123
Post by mr2nut123 »
Gazza_DJ wrote:Yeah, it's doable at home, just a drain plug and a fill plug. You can either use a hand pump to fill it (like this http://www.coleparmer.co.uk/Product/Han ... ed_id=3482) or use a tube and funnel.
Looks like there's a nice video on YouTube showing you how to do it too.
Thing is, this sounds like a clutch plate squeal, so would changing this fluid really be related? :-k
mr2garageswindon
Unlikely to be the oil, save the new oil for when the clutch is changed. Get new driveshaft seals too just in case. Pita when you get 95% done then realize you gotta take the shafts out again to replace em.
SonicSW20
Post by SonicSW20 »
mr2garageswindon wrote:Unlikely to be the oil, save the new oil for when the clutch is changed. Get new driveshaft seals too just in case. Pita when you get 95% done then realize you gotta take the shafts out again to replace em.
Definitely get new seals. They are very easy to damage when removing the driveshafts. They don't cost too much.
mr2nut123
Post by mr2nut123 »
So do we reckon it's a part of the clutch then? There is zero slip in any gear even at full boost, just that weird noise occasionally when on the biting point.
