![Wink :wink:](./images/smilies/icon_wink.gif)
MR2Kyle wrote:Ok thanks guys! I'll be onto a parts importer tomorrow and see if he can get me a 4th gen![]()
thanks again and I'll maybe see you around Dundee sometime
When you guys are saying rev 4 and 5 are you talking about generation of 3sgte or the revision 4-5 mr2 turbos.
If its the Generation of engine they won't come like this they will come like the caldina ST215 and upwards like pictured so not a straight fit again.![]()
If your talking about revision of Mr2 turbo then i can confirm that this is also wrong, i have stripped many Rev 4+5 mr2 turbos and i have only had 1 unit that came like this, all the others were of the weaker headstud design.
The only exception to this is the Beams setup which will come with the re-enforcements but again that block is different as far as bolting parts on and will also need machine modification to make it suitable.
These are all the material upgrade and design of the later Caldina blocks but machined by Toyota for a ST205 straight fit so no modification required.
Tim
ashley wrote:
.or would a v6 be better than a turbo.
androo007 wrote:There is of course the long old argument about the potentially weaker rev 3 blocks.
Of which I'm of the thoughts it's down to poor cooling/ fuelling management personally.
pbmr2 wrote:the later st246 engine was about the same but had an aluminium block.made up to 2007.
