its in the online bgb ... ive helped people before with this ... getting the muti meter prongs into the sensor and doing the feeler gauge its tricky ... two man job for sure ... good luck
2mad wrote:its in the online bgb ... ive helped people before with this ... getting the muti meter prongs into the sensor and doing the feeler gauge its tricky ... two man job for sure ... good luck
Best dodge I found was to make up a short jumper lead with chock block at one end to clamp onto the multi meter prongs and small spades at the other to attach to the pins on the sensor. Still a bit fiddly geting the spades on by "feel". But it does make it a lot easier single handed
Paul
Paul
I had a spare tps connector ... did the same thing ish .. like this ...
