Hi everyone
I've heard mixed things about Rev 5s with LSDs; some people have said that all Rev 5s have LSDs others have said that only later ones had them. Can anyone clear this up? Is there any sure way to see if your MR2 has an LSD (other than dumping the clutch at high revs and seeing how many lines of rubber you leave!).
Limited Slip Diffs
Re: Limited Slip Diffs
Put one wheel on the grass and one on the tarmac and hit the throttle
Doesn't the vin number give it away?
You can jack the car up from the middle of the subframe and then turn one wheel by hand, see which way the other one turns.
That don't work with a viscous LSD
Was it not standard on rev3 turbo onwards?
Both mine turn the same direction when jacked up and I'm sure its stock lsd. But what Ashley said makes sense about viscous , as they're basically open under normal use.
The axle code on the VIN plate will tell you which diff it was factory fitted with.
The only Rev5 NA's that have them as standard are JDM G-Limited's (with the BEAMS engine).
The vast majority of UK cars will not have one.
Nic wrote:The axle code on the VIN plate will tell you which diff it was factory fitted with.
Do you have a list of what the transaxle codes actually mean? It seems the 3 digits after the gearbox codes are relatively unknown on NA's.
Gazza_DJ wrote:Do you have a list of what the transaxle codes actually mean? It seems the 3 digits after the gearbox codes are relatively unknown on NA's.
I don't know the specific codes for the MR2 but the Toyota axle code usually denotes whether the car is fitted with an open or limited slip diff.
It does, I looked into this a few years ago now, and it seems no one is sure what the various codes are for the S series box across various markets and vehicles.
Gazza_DJ wrote:It does, I looked into this a few years ago now, and it seems no one is sure what the various codes are for the S series box across various markets and vehicles.
Googling 'S54 transmission' I see what you mean, there's a lot of varying/conflicting information on the subject.
The EPC seems to suggest that pre 06/1996 ALL UK 3SGE MR2's were fitted with an open diff and post 06/1996 ALL were fitted with an LSD.
With the JDM 3SGE MR2 the EPC shows that only some post 06/1996 models were fitted with an LSD.
If we knew the axle codes from an early and late revision UK MR2, it may help to identify which JDM models have which diff (it's usually the last digit of the axle code that denotes what type of diff it is.)
Wasn't it all from Rev3 onwards? 1994ish.
Toyota MR2 - 3S-GTE - 1991 Turbo - Yellow
Nic wrote:Gazza_DJ wrote:It does, I looked into this a few years ago now, and it seems no one is sure what the various codes are for the S series box across various markets and vehicles.
That's definitely not the case, I've never seen a UK NA with an LSD. My old Rev4 didn't, and my current Rev5 100% does not - I had the gearbox off a month ago.
I had a late model UK Rev 5 (2000 V reg) before and in the owners manual it said that it had an LSD, I've got a 1998 Rev 5 now but unfortunately don't have the owners manual for it.
I thought that sometimes, trying to get the power down pulling out of junctions, it feels like the diff is open which is what sparked the original question. Unfortunately I can't really remember what my previous MR2 felt like for comparison...
if the diff is only viscus then after 20 years it's going to be mostly open by now.
Really thinking of getting a proper diff and sticking it in a turbo box.
Just got my Dad to check his owners manual (he has a UK Rev 5 NA) and on page 92 it says:
"Limited-Slip Differential
Your Toyota is equipped with a limited-slip differential. If one rear wheel begins to spin, the limited-slip differential is designed to aid traction by automatically transmitting driving force to the other rear wheel"
[/img]
[/img]
My manual also says that, but I'm almost certain mine does not have an LSD.
What does the transaxle code say on your VIN plate in the front? Mine is 472.
It's in the long number at the bottom, the full version of mine is:
2CELB23-472S54
2CE = Sonic Shadow paint
LB23 = interior trim code
472 = transaxle code
S54 = gearbox code
2CELB23-472S54
S54 = gearbox code
If manufacturers go to all the trouble of making and fitting a LSD, why is it some people weld there's up?
What the idea behind that one?
And also why is it if clever old manufacturers develop clever old ABS systems do some people decide they can brake better without it?
BTW can you get quaife LSD's for 2's? anyone lavish enough to have purchased and fitted one? hows it drive any noticeable difference to a standard LSD.
masterbateson wrote:If manufacturers go to all the trouble of making and fitting a LSD, why is it some people weld there's up?
It's a cheap way of modifying older live axle vehicles that costs very little, and works pretty well.
masterbateson wrote:And also why is it if clever old manufacturers develop clever old ABS systems do some people decide they can brake better without it?
Because (in the case of the MR2) the ABS system is rubbish, and a driver with decent feel who is practiced at threshold braking can brake far better than it.
masterbateson wrote:BTW can you get quaife LSD's for 2's?
Yes.
masterbateson wrote:anyone lavish enough to have purchased and fitted one?
Yes- there are a good few MR2's out there with one fitted.
masterbateson wrote:hows it drive any noticeable difference to a standard LSD.
It works.
Gazza_DJ wrote:My manual also says that, but I'm almost certain mine does not have an LSD.
2CELB23-472S54
S54 = gearbox code
Yeah, mine is 472 as well
