2ZZ-GE, is it worth?
Ekona
Re: 2ZZ-GE, is it worth?
Post by Ekona »
Ah, the rolly-eyes smiley. Truly the epitome of return wit when you realise how stupid and narrow-minded your original comment was.
aussieGT
Post by aussieGT »
Ekona wrote:Ah, the rolly-eyes smiley. Truly the epitome of return wit when you realise how stupid and narrow-minded your original comment was.
LouisePiggin
Post by LouisePiggin »
:clap:
It was tongue in cheek.....get a grip
Torero
Post by Torero »
MilesH wrote:The swap is fairly simple and if you're using the standard 2zz ECU fuel consumption won't change much (in my experience).
It would work with the 5 speed gearbox BUT the ratios are all wrong for keeping the car in lift and you will loose a lot of the reason why you want to change the engine in the first place. The factory 2zz box is much more suited to the engine.
As for whether it being worth it. It is not a huge jump in performance terms and as the graph you put up shows the gains are at the top end so unless you plan to track the car (where you will feel a noticeable difference in performance at the top end) or if you like to rev the nuts off the car on road then the difference will not be huge.
I found that fitting an aftermarket ECU to a 2zz you can get noticeable gains lower down over that of a 1zz, but with the standard 2zz ECU they are indeed very similar.
Hope that helps
p.s. I have one in a track car and it is a definite improvement.
That's good advice Miles :thumleft: I've recently tried a MK3 and I'm pretty much sold on the idea of getting a MK3 and dropping a 2ZZ in it. I would like a 6 speed but rather than f@nny around trying to develop the best box for the job, I think I'll accept the 5 speed and spend on the ECU instead. :clap:
3VZ-FE V6 TRD Widebody Replica
Draven wrote "TRD dude. TRD... Can see awesomness from anywhere. "
Jaspa
Post by Jaspa »
Torero wrote: I would like a 6 speed but rather than f@nny around trying to develop the best box for the job, I think I'll accept the 5 speed and spend on the ECU instead. :clap:
From what I've read, You really want to keep the Celica (or Corolla) gearing as the ratios are alot better matched to the engine.
Stuart
I asked God for a bike, but I know God doesn't work that way. So I stole a bike and asked for forgiveness.
MilesH
Post by MilesH »
Stuart
Torero - not using a Celica or Corolla box REALLY will spoil the 2zz effect and any benefit you find from an aftermarket ECU and a map will be lost with the ratio of the gearbox.
I have a spare 2zz Celica gearbox if you need one? Infact I may even have the engine and all other parts needed for the conversion available.
pistol pete
Post by pistol pete »
Stuart
If torero isn't interested in the conversion stuff.. i might be..........
keep me updated if he doesn't :thumleft: :thumleft: :thumleft:
Torero
Post by Torero »
Stuart
Thanks Stuart at least I now know the best direction and I'll stick with the Celica/Corolla stock box.
I'm interested Miles and I've PM'd you. :thumleft:
Return to “MR2 MK3 2000-2007”
