Delighted to now have a key fob for my car since my last mr2 didn't have one. But anyhow I might as well not use the fob since the range is so poor that sometimes it doesnt pick it up at all and I'm left standing like a spare willy beside my car
If anyone has any info on how to increase the distance it would be well appreciated
1999 key fob distance?!?
Mk1b 1989 Mica Blue
Mk2 rev3 1993 NA Turquoise
Mk2 rev5 1999 Cosmos Blue with st215 conversion 😉
Re: 1999 key fob distance?!?
Try a fresh battery.
Done that already and it hasn't made the slightest bit of difference sadly
Mk1b 1989 Mica Blue
key fob
Hi got 1999 one as well with 2 key fobs and did put new batteries in both it makes no difference still can be hit and miss I believe if it will not respond press it over middle of windscreen low down as receiver is below dash there it works for me when its acting up
Mmm it's a bit of a pain though 😕 bit pointless having the fob then 😜
Mk1b 1989 Mica Blue
Do a "Top Gear" and put the fob to your temple, it actually works for me!
my rev4 has a short range but not that short. noramlly have to be near the back wheel at least for it to work. still easier than putting a key in a hole.
the topgear trick does indeed extend the range, only by a couple of meters though.
The range really depends on which side of the car you are standing, the receiver is just above the vent next to the drivers seat. I "modified" mine to make it go further. You can install a little extension aerial on it to improve the distance.
failing that replace it with a proper alarm
Search on here, it's a very common problem with the TVSS-IIIB ecu module.
They seriously degrade with age.
The TVSS-IIIB was fitted to UK rev4/5.
I wonder what it is that fails - caps maybe? Could be possible to repair.
Like the put it to your temple idea lol .. i think having a new security system fitted is a good idea ... its give or take been 20years ... or do it your self i did for 30 pounds .... 2 circuit immobilizer .. and for 30 pounds microwave proximity alarm ... best of luck mate ... ebays your friend
