Few questions.
kurkjones
Few questions.
Post by kurkjones »
Hi all.
Got just a few questions that I have been trying to figure out but need some help.
CAR - REV1 TURBO.
1: stereo has white noise lingering all the time. This a common issue with the old ones? Or is it a suppressor etc?
2: wind noise in cockpit, again, common? and if so where is the wind noise coming from, I hear around the tweeter cover on inside of mirror is common area. How to fix?
3: standard Fuel cut limit on a rev1 turbo? I fitted a blitz Nur spec R exhaust and started hitting fuel cut, so put on a grainger valve, disabled tvsv, fitted aftermarket boost gauge, what can I run? 13.4 psi? more/less?
4: polybush front arb opinions?
5: what size alloy are people loving and why? i run 17s, but hear handling/turn-in is better on 16s?
Look forward to the replies! thanks :)
Toyota MR2 - 3S-GTE - 1991 Turbo - Yellow
pbmr2
Re: Few questions.
Post by pbmr2 »
wind noise is the seal, search for it there are a number of topics about it. Not a hard fix
15s prob offer the best handling but offer very little in terms of tyre choice. I have 16s on min coming from 15 and find the steering much heavier. However there is now decent rubber on the wheels so it doesn`t slide around on damp patches.
Also find that the lower profile tyres on the 16 don`t soak up the bumps as well as the 15s.
I think the car needs a proper alignment. however it has more grip on 16s due to better tyres, the felt better most of the time except for ultimate grip due to limited options for 15s.
The turn in is worse on 16 but it can hold better in the corners. I can only imagine (never tried) 17 would be more of the same.
yes there are poly bushes for the ARBs.
kurkjones
Re: Few questions.
Post by kurkjones »
pbmr2 wrote:wind noise is the seal, search for it there are a number of topics about it. Not a hard fix
What seal is it that makes my radio make the noise?
And OK, good to know about the wheel situation. Just curious more then anything, quite like the wheels but a 40 sidewall doesn't go well with our rough roads in Scotland!
rgb
Re: Few questions.
Post by rgb »
yes yes yes yes yes.
doogal44
Re: Few questions.
Post by doogal44 »
Wind noise is the door seal
Radio noise is the power wire running to close to the speaker wires
Arb poly bushes are available in several sizes depending if you have original or uprated arbs.
kurkjones
Re: Few questions.
Post by kurkjones »
doogal44 wrote:Wind noise is the door seal
There is no leaking water around the door. Could it still be door seal, perhaps perished?
OK that's interesting, will need to look at the route of wire and see what I can do. Thanks.
Yeah would change the D bushes probably on front and see what like.
androo007
Re: Few questions.
Post by androo007 »
Common issue Google wind noise tweeters mr2.
danjama
Re: Few questions.
Post by danjama »
16's have been my favourite size, but I have run 17's mroe often than not. You can run 45 profiles on them, I have 205/45 8j on the front and 245/45 on the rear. Soaks up the bumps and holes much better than 40 profile.
2mad
Re: Few questions.
Post by 2mad »
[quote="kurkjones" started hitting fuel cut, so put on a grainger valve, disabled tvsv, fitted aftermarket boost gauge, what can I run? 13.4 psi? more/less?
[/quote]
13 psi is the one ... a good amount of boost mate :thumleft:
kurkjones
Re: Few questions.
Post by kurkjones »
2mad wrote:[quote="kurkjones" started hitting fuel cut, so put on a grainger valve, disabled tvsv, fitted aftermarket boost gauge, what can I run? 13.4 psi? more/less?
13 psi is the one ... a good amount of boost mate :thumleft:[/quote]
Thanks man, will try get it set around that amount. It's set by MBC at 10psi at minute, must be very sensitive, even half a turn of the bolt on the grainger valve and i was hitting boost cut again! Will try it slowly adjusting the bolt. :)
2mad
Re: Few questions.
Post by 2mad »
Thanks man, will try get it set around that amount. It's set by MBC at 10psi at minute, must be very sensitive, even half a turn of the bolt on the grainger valve and i was hitting boost cut again! Will try it slowly adjusting the bolt. :)[/quote]
If you remove the vac hose from the map sensor ... and cap it off ... no more fuel cut :wink: ... keep an eye on boost though dont want to grenade your engine 8-[
gmac90
Re: Few questions.
Post by gmac90 »
If you remove the vac hose from the map sensor ... and cap it off ... no more fuel cut :wink: ... keep an eye on boost though dont want to grenade your engine 8-[[/quote]
Is this boost with running the CT26 Turbo? Would it be the same if it was a REV 1 running a CT20B turbo?
2mad
Re: Few questions.
Post by 2mad »
Is this boost with running the CT26 Turbo? Would it be the same if it was a REV 1 running a CT20B turbo?[/quote]
Yes it works the same ct26 or ct20b ... just make sure you have a good gauge , one with an over boost alarm is ideal :thumleft:
peake201
1990 toyota mr2 altinator removal
Post by peake201 »
on the forum it says remove wheel and then plastic panel inside of wheel arch to gain access to altinator ? there is no panel to remove on MY mr2 can any one explain .??? how do i get at the altinator to remove it....Thanks..
2mad
Re: 1990 toyota mr2 altinator removal
Post by 2mad »
peake201 wrote:on the forum it says remove wheel and then plastic panel inside of wheel arch to gain access to altinator ? there is no panel to remove on MY mr2 can any one explain .??? how do i get at the altinator to remove it....Thanks..
Hi mate start a new thread on this topic, someone will help .. i dropped mine out the bottom squeezing it past the subframe .
kurkjones
Re: Few questions.
Post by kurkjones »
Yeah i am running CT26 turbo on Rev 1 as standard.
I saw someone mention capping the vac hose, I assume that is the one that runs to the bottom of the stock boost pressure sensor unit?
Also looking into an EBC instead of MBC, the MBC works fine but I like having the ability to adjust in cockpit and also just by using buttons increasing or decreasing it by small increments. Any for sale please message me!
peake201
Post by peake201 »
