I
understand wanting to preserve off-boost response by running a higher static CR, but if you do the maths- you really lose very little power by dropping 0.5:1.
.it's a surprise when you run the numbers!
Also- this then allows you to make FAR more power when on boost as you don't have to overly retard ignition- which is a big issue on the 3S engines.
Other designs of engine can lap it up- but these just don't, and you end up with really high EGTs, a sign of an engine not running to it's full potential.
But that said- it's all up to you and whoever designs the engine with you, and exactly what you want it to do.
If you want 500hp to say you have it, but then rarely drive it at that level- then yeah, a higher CR would be fine.
If you want to drive it at peal boost levels on a sustained basis, then you are risking reliability issues with a higher CR.
You can build a 3S to run 2 bar of boost at 11:1 CR, but don't expect it to do it all day long.
.and you'll need to be using a far higher octane fuel than we get in the UK pumps.
All in my opinion, you'll get different stories from other members on here
