Boost problems
Jevanchivers
Boost problems
Post by Jevanchivers »
Hi, have a problem with my car over boosting in every gear, I've changed the actuator, on my boost controller it boosts up 1.3 by 5k revs in third , just wanna get it sorted to I can drive it properly, so my question is, is there any trusted mr2 mechanics in the normal area?!
androo007
Re: Boost problems
Post by androo007 »
What area
What controller
What's your setup
Jevanchivers
Re: Boost problems
Norfolk,
Jevanchivers
Re: Boost problems
Hks controller
Blitz exhaust
Greddy bov connected near intercooler,
Fen sport actuator
Cone filter known make
Brought with the problem
I had the actuator fit, but hasn't helped, it's my first mr2 turbo and a little like walking into the unknown ,
It's only done 55k
Al-sw20
Re: Boost problems
Post by Al-sw20 »
Has the t/vsv been disabled? If not this could be why it over boosts.
Does it have a cheap aftermarket downpipe ? The waste gate could be catching inside the pipe.
Jevanchivers
Re: Boost problems
No down pipe just blitz from down pipe, and the waste gate isn't catching
And it is disconnected
Ryan S
Re: Boost problems
Post by Ryan S »
Jevanchivers wrote:No down pipe just blitz from down pipe, and the waste gate isn't catching
Your wastegate is disconnected? Yeah that'll definitely cause problems.
Jevanchivers
Re: Boost problems
I mean the t vsv id disabled,
I have taken it to a normal every day garage and why can't find the problem,
So any of the basic,s I'm sure have been checked,
I would take it to pacific works, but don't wanna be driving it 2 1/2 hours there,
Any specialist In the Norwich area?!
androo007
Re: Boost problems
Post by androo007 »
1.3 Is fuel cut.... not good news.
Got pics of how it's plumbed up? Firewall to solenoid to actuator to turbo
Next is checking for air leaks
Also what settings is controller at. Set everything to 0
Ryan S
Re: Boost problems
Post by Ryan S »
Sounds a lot like the controller isn't plummed in properly to the actuator. The turbo is just boosting with no control. The controller/solenoid should sit between the actuator and turbo.
chrismit
Re: Boost problems
Post by chrismit »
Like above you need to check to make sure your boost controller is correctly connected, but with the decat etc your system may just be too free flowing that not enough exhaust gasses can escape and the boost is climbing.. I had a similar issue with the same mods after installing my hks hi power exhaust. But the combination of the blitz ebc and a restrictor ring(dont hate) at the bottom of my downpipe to give some back pressure cured the issue and it can hold boost now without climb at anything from 0.9 bar and up.
rgb
Re: Boost problems
Post by rgb »
what spring is in the acuator cause you cant go lower
Jevanchivers
Re: Boost problems
Thanks for the comments, I'll get the car out and have a look, get sme pics, any1 in the Norwich area to have a look?! As I won't knw if controller is connected right or not
Ryan S
Re: Boost problems
Post by Ryan S »
Jevanchivers wrote:Thanks for the comments, I'll get the car out and have a look, get sme pics, any1 in the Norwich area to have a look?! As I won't knw if controller is connected right or not
Take the controller out of the equation. Get a piece of silicone hose and chuck it from actuator to the turbo. If it doesn't overboost you'll know whether it's that or not :thumleft:
Jevanchivers
Re: Boost problems
If that removes the controller how do I then know if it over boosting, sorry if it's a dumb question
Ryan S
Re: Boost problems
Post by Ryan S »
Jevanchivers wrote:If that removes the controller how do I then know if it over boosting, sorry if it's a dumb question
Aw ok, is your controller also your gauge?
2mad
Re: Boost problems
Post by 2mad »
Do this bud ... sheppys spot on ... get back to us with results ... ps. 1.3bar is to high =;
Jevanchivers
Re: Boost problems
Thanks for the help guys, yes my controller is a gauge aswell, it just sits in the ash tray, so how will I knw what it's boosting without it? Plug the fuel cut pipe back on? As a rough test?
Not gunna get out in the car until the weekend, please bare with me guys lol
Ryan S
Re: Boost problems
Post by Ryan S »
Jevanchivers wrote:Thanks for the help guys, yes my controller is a gauge aswell, it just sits in the ash tray, so how will I knw what it's boosting without it? Plug the fuel cut pipe back on? As a rough test?
This is not ideal but yeah you could essentially let it hit fuel cut (at your own risk). If it boost to stock boost you won't hit fuel cut. If you hit fuel cut you know the controller is at fault.
I would personally recommend waiting till you have a boost gauge. I have a very sneaky suspicion that the controller is plumbed in wrong :thumleft:
Willenium
Re: Boost problems
Post by Willenium »
If your EBC is anything like my Profec then you'll have a vacuum feed going to the controller and then some more to connect the solenoid between the turbo and actuator. Remove the solenoid plumbing from the equation by just connecting the silicone pipe from turbo straight to the actuator but leave the vacuum pipe going to the controller which means it will still read boost but not be able to alter it.
