Manual boost controller
kurkjones
Post by kurkjones »
Hi all.
I've bought this boost controller and wondering if anyone can tell me where is best to plumb into? I've heard between actutator and turbo? Any advance or other options? Thanks.
Toyota MR2 - 3S-GTE - 1991 Turbo - Yellow
markstevieandmads
Re: Manual boost controller
Post by markstevieandmads »
Don't use it.
Use a Grainger type one....alot better
kurkjones
Post by kurkjones »
markstevieandmads wrote:Don't use it.
Do you have a link to any, I've just tried to find some but no luck.
markstevieandmads
This is what I've used on all my turbo cars including my mr2. Nice solid MBC which holds boost fine.
EBay item
220537192173
kurkjones
Post by kurkjones »
Thanks for the link, looks a lot simpler then the Turbosmart one. Get one ordered soon and see how it goes, it just gets fitted in-between actuator and turbo yes? From what I see it's only a short vacuum hose between the two, if I were to lengthen it and mount it somewhere it could be better.
Have you done this and if so where did you choose? Thanks again.
markstevieandmads
Keep the hoses as short as possible.
The longer they are the more probs you have.
Once set correctly then u won't need to adjust. I just kept running up and down a local dual carriageway then pulling off adjusting etc until I was right.
Havent needed to touch it since and that was 2yrs ago.
2mad
Post by 2mad »
markstevieandmads wrote:This is what I've used on all my turbo cars including my mr2. Nice solid MBC which holds boost fine.
EBay item
220537192173
Yep had a few of these n there sweet, very stable boost :thumleft:
kurkjones
Post by kurkjones »
Alright I'll keep them short as possible then. Just ordered one now, thanks a lot for the suggestions! Love this IMOC website!
mr299ron
Post by mr299ron »
I too have one of those boost controllers and have absolutely no issues.
I used the following document when setting mine up.
http://www.twosrus.com/Articles/Install ... ctions.PDF
Fairly easy, just have to read parts over a few times and grab an understanding of how it works. Pretty simple :)
