Andy's Rev 3 Turbo - Project complete.
C35Rob
Re: Andy's Rev 3 Turbo - Project complete.
Post by C35Rob »
If the KYB's are in good nick then I'd keep them, my car had GAB/KYB gymkhana struts and Unknown (presumed to be swift) springs on it before the HSD's and they were great, shame one started leaking tbh - ended up skipping the lot of them cause I thought nobody would want 3 good ones!
Don't discount the TD06 just yet, you may be pleasantly surprised, plus, you can still upgrade it, or spray water pre turbo to expand the compressor map
androo007
Post by androo007 »
Yeah Rob I had a drive around in the other car and they were really nice. I think it's got stock springs with it though so may need something a little lower.
Were they not able to have rebuilt at all? I see a lot of specialists around and assumed pretty much any strut could be rebuilt one way or another?
Good shout on the meth kit - AEM 2 stage is definitely on the cards. The Link can tell it to only spray when boost is x psi and or IAT is above x deg which is super cool.
C35Rob
Post by C35Rob »
Tbh I didn't look into it, being obscure discontinued Japanese stuff I assumed parts would be hard to come by, and I wanted the extra camber/ride height adjustability of the Coilovers.
Although if I remember right there was a proper gland nut on the top so they may be able to be dismantled, probably not worth it though
Have you gone for the link plug in or wire in?
androo007
Post by androo007 »
Straight plug in, with the labour to wire it in I didn't see any benefit in going wire in. Think the ecu, fast response air temp sensor and brass doofer thingy was about £1050. Further £360 for fitting and mapping (road tune)
I'd like to get it on the rollers after though just to be a number pony, but also good to see how it's been mapper interests me.
Chumbaside
Post by Chumbaside »
I've been doing a lot of research on the Link ECUs - it's very hard to get good info, even form Link themselves (due to so many different versions and a crappy website!)
I've discounted the plug-in for a number of reasons:
- it's based on the old Xtreme
- can't access all the additional I/O (you can get to some with the extra loom though)
- limited by the factory loom and reusing 20+ year-old wiring
Then I started looking at the Storm vs the Fury...
Fury has onboard:
- wideband O2 controller
- MAP sensor
- Peak & Hold drivers so can run low impedance injectors directly (so all factory MR2 Injectors, Sard 800's etc) without the need for ballast resistor
Storm has:
- onboard MAP sensor (which no-one references anywhere!)
If you've removed air con, have uprated fuel pump and run new wring, done away with factory boost control, Air con idle up etc, so much of the factory wiring is no longer used. I've also removed ABS and a bunch of other stuff so decided fully wired in, with brand new cable and plugs, was the way forward if a little more expensive. The Storm and Fury both give room to grow with full data logging capability too, so all in all the best option (for me).
I though it might help you if I shared my thought process :thumleft:
100% improvement on the tint removal Andy :thumleft:
Regarding the engine, should have seized the opportunity to get that cam cover, inlet mani and throttle body painted while the engine was being built.
androo007
Post by androo007 »
Thanks Gents. Yeah cheers Craig - it was a home jobbie not a professional job, much happier now. Although red / orange does clash a little.
Totally right about the rocker cover!!!!! #-o #-o
Mark, interesting thoughts there.
The G4 has an internal MAP sensor i believe and runs the very latest software. I dont mind using the OEM loom.... often these things start getting dodgy when you mess with them... best left alone IMO.
I believe the G4 also has the wideband.
Interesting looking at the different Fury / Storm etc - i was just given the "link G4" option - no Fury / Extreme / Poo version or anything. I guess i have just the bog standard?
To be honest, for me - I will want to just get in it and drive. I wont be tracking or dragging the car, so not likely to want or need much else. I decided on the G4 more for the larger map grid over the PFC for additional safety.
But good points well made there..... I may pop Simon back some more questions. Thank you!
androo007 wrote:Thanks Gents. Yeah cheers Craig - it was a home jobbie not a professional job, much happier now. Although red / orange does clash a little.
Well, you could always remove the orange from the fronts, with some rev 5 oem front clear lenses.
Here's some I prepared earlier!
http://www.imoc.co.uk/forums/viewtopic.php?t=190828
/shameless :mrgreen:
androo007
Post by androo007 »
:lol: :lol: :lol: i just sold a set from my breaker for £15 :lol: drat!
androo007 wrote::lol: :lol: :lol: i just sold a set from my breaker for £15 :lol: drat!
:shock:
androo007
Post by androo007 »
WITH loom and bulb holder :lol: :lol: :lol: :lol: :lol: :lol:
androo007 wrote:WITH loom and bulb holder :lol: :lol: :lol: :lol: :lol: :lol:
Double :shock:
Someone got a reet bargain! They're about £165 new, complete from Mr T:
side lenses x2
main units x 2
looms x 2
Edited to add:
Yours were aftermarket jobbies:
mine are oem Toyota parts.
androo007
Post by androo007 »
ahhh, so better? 8) :lol:
androo007 wrote:ahhh, so better? 8) :lol:
The oem Toyota items are far better quality. 8)
C35Rob
Post by C35Rob »
I think if you can be bothered to do it then the wire in is a better option for the reasons chumbaside stated - extra I/O etc, but for what you want/need the plug in will be totally adequate. And gives the flexibility to return to standard or easily sell on if you break it
I'm sure the plug in has a wideband input but not a controller, just means you need to run the 0-5v signal from an aftermarket gauge.
Re: the resolution, the PFC has a 20x20 map, so 400 cells, the link has 440, not much more really. But it's more about how well it interpolates between them, some ecus have as low as 16x16 maps but can interpolate between the cells very well.
androo007
Post by androo007 »
Got the Rota GTRs on, not sure if I like black wheels on red.... but perfect style for me. Love 5 spoke and these are mint
androo007
Post by androo007 »
Just a few small bits this week
Pete popped me back my SARD 800cc injectors sonic cleaned just before I bought them all with new o rings seated in a fuel rail ready to go along with injector resistor pack soldered for the right resistance :
Lovely matt black customised heat shield (again by Pete)
Slowly been popping small bits on the engine bay mainly swapping out the ill fitting silicone joiners from the chargecooler kit and decided the strut bar I had needed a lick of paint so did Toyota red to match the bodywork:
Quite happy with how it's looking now... a little more loved. Still more to go though!
Mapping was booked for Wednesday but couple of things have pushed it back. Now hoping for the week after if I get the last few tweaks sorted
androo007
Post by androo007 »
Only a wee update, but maybe of use to other people that forge in the future.
Popped to Mr T and Opie oils and got my final oil choice for use
Oil was £45 delivered from eBay - cheaper than going direct even with a 10% off code. Crazy!!!
jimGTS
Post by jimGTS »
looks great with the black wheels
androo007
Post by androo007 »
Thanks Jim!
