i bought a rev2 turbo earlier this year spent 8 months replacing front end with fiberglass wings built my own rear diffuser had a full respray really happy with the outcome ive had it on the road for about 5 weeks but the quick shift it was already fitted with just seems pants i dont like it ive got pretty used to it now but i like how normal gear boxes drop back to the center and i can be a bit more care free but with the quick shift i spend to much time concentrating on gear change
basically how do i go about swapping it out and what shift is the best to stick in ive heard a rev 3 + is better
ive found a 1997 shifter on ebay not sure if its anygood if anyone could check it out please http://www.ebay.co.uk/itm/TOYOTA-MR2-GT ... Swqu9VS9Y4
so any help would be great and if anyone has one for sale great thanks in advance *Title edited by Imoc Mod*
i thought i could just replace with a complete unit with the gear stick just drop the cables off and direct replacement so ill see what else turns up first mate thanks alot for the info though ill give a few days days for more suggestions before i make up my mind cheers
tonym wrote:i thought i could just replace with a complete unit with the gear stick just drop the cables off and direct replacement so ill see what else turns up first mate thanks alot for the info though ill give a few days days for more suggestions before i make up my mind cheers
yeh its very easy to just replace the whole unit without getting fiddly over little bits and pieces i did the swap myself as a total novice and it slotted in nice
If you're just changing the assembly it's easy, just four bolts and a couple of clips you can remove with pliers which hold the linkages iirc.
But yes the item you've linked looks correct
ive just bought a 1997 shifter off ebay hoping this works well i cant weld so im just gonna drop in this standard one for now and maybe think about this in the future maybe in the summer when im tinkering thanks for the link though i think the one in my tubby at the moment is a twenty pound short shift ebay jobby just does not feel good at all
