A simple search would tell u it does with a little bit of persuasion with a soft mallet to push the rear panel back a bit tonallow the rev 3 panel to fit.
You can use the rev 1 light fittings.
You will need rev 3 rear lights and indicators which are separate,rear rev 3 label and the mounting brackets.
