CalMac wrote:Roughly how many miles/how long will the drive be? I'm crap at Geography but it looks like maybe 2.5 hours in a triangle?
Just thinking best way to come from Northampton, do the run and then either find a hotel that won't object to me rocking up in the early hours or driving home after feeling pretty knackered
I'll be coming from Milton Keynes so we can travel down together if you like. Easier to do the journey back with a wingman lol
Alternatively you could check into a local Premier Inn or similar? If you check in before the run you'll have your room-key ready so you won't need to worry about checking in in the early hours. Plus it's Friday night, so you probably won't be the only person making noise in the early hours
2001 BMW M5 (Bahnstormer) | 2004 RX8 231 (the Racecat) | 2001 Volvo V70 (Swedish eBay barge)
Ben wrote:In that case I apologise in advance for not being in an MR2. If it helps, and if things go to plan, I will probably be in something with a V8
We didn't object to the Drift Spec MG....
That's enough from peanut gallery please!
It is about 2.5 hours, given we have a stop in the middle as well.
What I will say is a lot of people when we come back up the A3, instead of turning off to head back to the start point, peel off and carry on straight up and head for home.
