Once the tank is physically only half full and under it will read less, properly.
Also, the empty fuel light seems to always be on.
![bounce :bounce:](./images/smilies/icon_bounce.gif)
Where is the fuel gauge sensor/reader and is it a total xxxx of a job to replace?
mr299ron wrote:My fuel gauge only reads above half at any level above half.e.g.
If I stick a full tank in gauge reads half.
If I stick 3/4 in it still reads half.
Once the tank is physically only half full and under it will read less, properly.However, it won't read on empty once I'm on empty.
I actually ran out of fuel because of this.
Also, the empty fuel light seems to always be on.This can be when I have half a tank, half a tank, half a tank, and a little less than half a tank.
rgb wrote:pauln is right but sometimes the fuel gauge gets messed up when people fit lockwood dials and move the needle.
Pauln wrote:rgb wrote:pauln is right but sometimes the fuel gauge gets messed up when people fit lockwood dials and move the needle.
Too true, and not just the fuel gauge![]()
Spent ages trying to work out why my turbo had a high idle speed.It didn't actually, the previous owner hadn't fitted the tacho needle back correctly when he fitted Lockwood dials.
Just add injury to insult, he also fitted blue leds at the same time, so all the needles were actually invisible at night![]()
But that's OT.
