My rev 3 tubby is not boosting properly
It goes up to 3k/4k and then lags it feels like there's no turbo
I have checked all the boost pipes and they seem ok
any help would be great
[Mk2] [Turbo] No power on boost
Re: [Mk2] [Turbo] No power on boost
pop the turbo hose off and see if the turbo turbine feels ok.
just been and checked and there's play
can I rebuild it myself or is it better get a company to do it
Sounds more likely to be a different problem unless the turbo is properly fubarred. No boost at all?
There is still boost there it just lags and pops and splutters from about 3/4k
How old is your ignition?
Have you checked for codes?
We have replament CT26 turbos in stock if you need one or can rebuild CT20B
Ive got no fault codes
Its a ct20b, what price would a rebuild be on it and what kind of turnaround time
Matt49a wrote:Ive got no fault codes
I would need to see it to see how bad it is, but if it was just bearings and seals I would say around £300 to £350.
Time would be about a week or just over depending on the parts needed.
Boost lag and popping/sputtering doesn't come from worn bearings or seals. Check your ignition components and your static timing first.
Sounds more like ignition, fuel or vacuum issue
