Engine Does Not Tick Over When Hot
elbon50
Post by elbon50 »
Engine starts from cold & runs well, accelerates strongly, etc
BUT
When it reaches full running temperature it stalls at tickover revs
Any ideas please ?
Peter
1989 MR2 Mk1 NA T-bar
1998 Ssangyong Korando GLS
2011 Honda Civic Type R
PW@Woodsport
Re: Engine Does Not Tick Over When Hot
Post by PW@Woodsport »
Not enough bypass air getting past the throttle, open the idle air bleed a few turns.
elbon50
Post by elbon50 »
OK thanks Paul
Will try that :thumleft:
Peter
elbon50
Post by elbon50 »
Yes, opened idle air bleed a few turns
Engine now not stalling when hot :thumleft:
BUT
It hunts between about 1100 & 1800 revs when hot
Changed coolant recently but i think its fully bled out now :-k
Peter
SySanguinary
Post by SySanguinary »
elbon50 wrote:Yes, opened idle air bleed a few turns
BUT
Keep bleeding. And when you're done, bleed some more! :thumleft:
elbon50
Post by elbon50 »
Yes I did wonder if it may be that
Don't seem to be getting any more air out
But may be some still in there ](*,)
Peter
PW@Woodsport
Air trapped in the coolant going to the waxstat giving it too much bypass air when hot, as said above bleed it out.
You can test the waxstat as the culprit by blocking off the 5p sized hole inside the throttle body with your finger, the revs should drop to 800-900.
Tiamat
Post by Tiamat »
elbon50 wrote:
If you know someone with a high lift jack (for 4x4s) then use that, can really raise the back then. Its how I do mine.
LimeyMk1
Post by LimeyMk1 »
Or fit a manual choke then loop off the feed lines to the throttle body as, other than the filler cap, that's the highest point that the coolant reaches in the engine bay. Makes bleeding the coolant a lot easier and the air isn't heated up as much (debatable benefit). :thumleft:
un1eash
Post by un1eash »
Another tip, when setting the idle with the idle screw make sure everything electrical including lights, blowers etc is turned off. Made this mistake before and revs kept dropping too low.
