As I wasn't making any progress I decided to clean up my old throttle body and check everything over.
All resistances were within spec, applying 12 v opened and closed the ISCV.
So I then tried adjusting the ISCV to make sure it was fully closing.
Having checked and setup the TPS, I then swapped the throttle bodies back as I had at least seen a 800 rpm idle at one point with the original throttle body.
Unfortunately this made absolutely no difference and she still idles around 1,100rpm when warm.
Whilst the throttle body was off I noticed another vac line underneath the body that I hadn't changed, so I replaced that just in case the old one was leaking.
I also found a couple of valve cover bolts were loose so tightened them.
Today I unplugged the MAF connector and checked that the resistances were within spec, and rechecked the
"idle screw".
I also tried the dodge suggested in these forums of starting the engine multiple times, and removing the EFI fuse for 10 mins.
But she still refuses to idle at anything below 1100 rpm as indicated on the tach.
Mind you I do wonder how accurate that is as I've noticed when you turn the ignition on without starting the engine the needle goes up slightly I'd guess around 100 revs or so.
It's a replacement gauge, so perhaps the previous owner took the needle of when he fitted Speedhut dials.
So, as you say, for
£15 perhaps it might be worth changing the EFI temperature sensor.
It's definitely worth checking your ECU to see if the capacitors are leaking as these can then damage the tracks and cause no end of issues.
Any way I'll give her a run in the week to blow out the cobwebs and check everything else is working OK.
Paul
