where can i buy mr2 turbo rev3 rear toe control arms from...
Mine have seised up...
any aftermarket or oem sellers out there I would much appreciate it if anyone whos
MR2 REV 3 TURBO 450BHP
3000GT VR4 TT 500BHP
EVO X FQ360
EVO X FQ360
Re: where can i buy mr2 turbo rev3 rear toe control arms
Thanks just wanted oem one and got ftom mr2-ben
EVO X FQ360
EVO X FQ360
QUOC2008 wrote:where can i buy mr2 turbo rev3 rear toe control arms from...
Just done rear tracking on my Turbo after rear shock replacement mine were rock solid.
I wire brushed the exposed threads as much as possible so the lock nuts can move down them without picking up all the rust and stuff.
Soaked in GT85 overnight then clamped in vice, got my MAPP gas burner on them and heated them up a bit the 2 locking nuts came undone easy as pie and the centre section also came undone ok
Took all apart wire brushed them and the threads etc shed load of copper grease and put back together, been on car for 22 years so they were like rock solid to start with.
Don't waist time with WD40 as it does not penetrate at all go for the GT85 works a treat and with something as simple as fire (heat) they come undone.
A bit late for you now but worth noting for future.
