Recently bought turbo box including driveshafts with standard lsd off ebay for a song, not yet collected from seller so may well be too good to be true.
Use my rev 2 na mostly for relaxed cruising, although I may have a crack at a very occasional hillclimb event
(less important than touring around).
Intention is to get more relaxed and economical cruising, with LSD coming in handy on twisties
- obviously the box is heavier plus the longer gearing so I'll take the hit on acceleration, which hopefully shouldn't be too badly affected?
Three questions:
first, I know I need turbo hubs
- will hubs off any model year turbo be ok?
Second, has anyone fitted a turbo box to an n/a and were you pleased with results?
Third, any way I can test if the box is working properly
(doubtful) before I fit the thing only to find its a dud.
(at least seller tells me the shafts rotate the same way each side so does have lsd)
I'd be interested to hear anyone's thoughts about whether or not swapping to a turbo tranny is a good move, or not
