I'm in the process of rebuilding my suspension including all ball joints and bushes. Due to extortionate prices for the OEM rear outer track rod ends, I hunted for alternatives. I stumbled across the TREs from a 1978-1986 Vauxhaul Carlton... and they are a perfect fit!
They don't have the tab at the end, which i find rather pointless anyway (correct me if im wrong). I hope this helps someone
... I would like to provide a photo but i havent posted enough yet...
Mk1a rear track rod ball joint- nifty replacement trick!
Rear tie bar
That's a good find. Have you any luck finding the m14 turnbuckle which connects the two rods together. Have found the threaded bar with left and right handed threads but the pitch is 2mm not 1.5mm.
Re: Mk1a rear track rod ball joint- nifty replacement trick!
not yet...
mine are ok (refurbish-able)
You can get them from amazon.com for less than a fiver but they won't shop to the UK
what about the ones from
mcgillmotorsport.com/m14-turnbuckle-link-adjustment-215mm-255mm-linkage-14mm-828/
Rear tie bar
That's where I ordered some from but they were 2mm pitch thread and not 1.5mm.
do toyota still sell the originals?
- Lauren
- IMOC Committee
Hennus wrote:do toyota still sell the originals?
I believe they do.
2020 GR Yaris - Circuit Pack
Rear tie bars
Have found that the ball joint and bar off a bmw 5 series 1985 is ideal replacement for the rear. The ball joint has a left handed 14 mm male 1.5 thread pitch and the tube has left and right handed thread.
[/url]
[/url]
You need to use an external picture library (Photobucket, Flickr or similar) to post pics Mark
Peter
1989 MR2 Mk1 NA T-bar
1998 Ssangyong Korando GLS
2011 Honda Civic Type R
Rear tie bars
Yes used photo bucket but can't seem to get it to work.
When you've selected the image click on IMG to copy
Then paste into your imoc post
Peter
Rear tie bars
Can't seem to get the hang of this.
