[Mk2] [Turbo] JDM Side Repeater removal
TheCombover
Post by TheCombover »
How do I remove the side repeaters??
Do I use a screwdriver to pry it off?
Or are there hidden screws or nuts behind the wheel liner?
acf8181
Re: [Mk2] [Turbo] JDM Side Repeater removal
Post by acf8181 »
TheCombover wrote:How do I remove the side repeaters??
is it not attached to the trim from inside....so have to remove the trim first (think there's a screw under front indicator reflector, and one under wheel arch.
...pure guesswork by the way, sure someone will be along who knows soon
TheCombover
That is what I assumed!
Hope there is a different way to do it. I don't fancy taking the wheel off so I can take the wheel arch liner off just to switch out my side repeaters :?
DB Mr2
Post by DB Mr2 »
Hi thecombover if you are just replacing t he bulb then removing some of the arch liner screws and bending it back slightly gave me enough room.
If you are replacing whole unit read the guide below I found it helpful but wished I had soaked the nuts in wd40 as they sheared off.
http://gawlowski.com/mr2/trim.html
TheCombover
That link helped!
Annoyingly the nuts are bu88ered and won't come off:(
Return to “Electrical”
