Hi,
Today I have been following a rev 1 diagram on how to adjust the rev2 body loom to be compatible with a rev 3 engine loom. Followed it and still cant get the starter motor to fire. Anyone got any ideas or info that will help me along
Thank you in advance
Tony
HELP!!!! Wiring on rev 2 with rev 3 engine
Re: HELP!!!! Wiring on rev 2 with rev 3 engine
Earth the starter relay.
Ok thanks Peter. I'll give that a try. I'll let you know how I get on.
Make sure the main gearbox to chassis earth strap is attached and clean/tight, you will have a fusebox meltdown if you try and crank the engine without that.
Got it a sorted. Was an earth wire. Thanks for your help chaps. Now running like a dream and back on the road yay
