Starting procedure for oil circulation after 9 month layup
Rob
Post by Rob »
Bit irrelevant as I have started it anyway, but I changed the oil, removed the EFI fuse so it couldn't fire and cranked the car over for about 10 seconds.
Would this have spun the oil pump round and circulated the oil without running dry immediately?
rev3turbo
Re: Starting procedure for oil circulation after 9 month layup
Post by rev3turbo »
if the oil pressure light went out straight away, then that will give you your answer.
mine gets laid up for 6+ months.. i just turn the key, never had any issues.
2mad
Post by 2mad »
Rob wrote:Bit irrelevant as I have started it anyway, but I changed the oil, removed the EFI fuse so it couldn't fire and cranked the car over for about 10 seconds.
Sounds right too me .. i'd pull the king lead .. same difference :thumleft:
Ryan S
Post by Ryan S »
You'd flood it doing that as it'd still inject fuel.
Just start it up as normal :)
2mad
Post by 2mad »
sheppy wrote:You'd flood it doing that as it'd still inject fuel.
Good point #-o .. i'll pull the efi or injector fuse next time :thumleft:
Rob
Post by Rob »
EFI fuel is nice and easy to pull so that's why it is my preference.
Thanks for the replies - never like starting a car without any oil circulated after a fair amount of time but I agree it won't really do much harm.
Odin_S
Post by Odin_S »
How is your car running Rob? I remember following this car years back :lol:
Rob
Post by Rob »
Hey mate, yeah I've had it a few years!
It's had a windows out respray and I've been reassembling it and tarting it up underneath the past 9 months. Special wheels on their way too - loving yours by the way!
